Problem with numproc and cachesize
rdiaz82
Hi!
I have reinstalled a instance with Pararell Plesk 11 and I have configured three domains in that instance. I don´t know why but every 4 or 5 hour the number of mail process start to increase and the system is blocked and I have to reboot the instance to solve the problem...
Here is attached a process list before reboot the instance in one of this situations:
Code:
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.0  0.0  19232  1416 ?        Ss   19:45   0:00 init
root         2  0.0  0.0      0     0 ?        S    19:45   0:00 [kthreadd/621891]
root         3  0.0  0.0      0     0 ?        S    19:45   0:00 [khelper/6218914]
root       131  0.0  0.0  10640   544 ?        S<s  19:45   0:00 /sbin/udevd -d
root       468  0.0  0.0 183548  1452 ?        Sl   19:45   0:00 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
root       494  0.0  0.0  22096  1048 ?        Ss   19:45   0:00 xinetd -stayalive -pidfile /var/run/xinetd.pid
root       501  0.0  0.0  64308   900 ?        Ss   19:45   0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam -n 2
root       503  0.0  0.0  64308   648 ?        S    19:45   0:00 /usr/sbin/saslauthd -m /var/run/saslauthd -a pam -n 2
root       514  0.0  0.0  13972   724 ?        S    19:45   0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=imapd -maxprocs=40 -maxperip=4 -pid=/var/run/imapd.pid -nodnslookup -noidentlookup 143 /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root       517  0.0  0.0   4064   600 ?        S    19:45   0:00 /usr/sbin/courierlogger imapd
root       524  0.0  0.0  13972   724 ?        S    19:45   0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=imapd-ssl -maxprocs=40 -maxperip=4 -pid=/var/run/imapd-ssl.pid -nodnslookup -noidentlookup 993 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root       527  0.0  0.0   4064   596 ?        S    19:45   0:00 /usr/sbin/courierlogger imapd-ssl
root       532  0.0  0.0  13972   724 ?        S    19:45   0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=pop3d -maxprocs=40 -maxperip=4 -pid=/var/run/pop3d.pid -nodnslookup -noidentlookup 110 /usr/sbin/pop3login /usr/lib/courier-imap/authlib/authpsa /usr/bin/pop3d Maildir
root       535  0.0  0.0   4064   600 ?        S    19:45   0:00 /usr/sbin/courierlogger pop3d
root       541  0.0  0.0  13972   728 ?        S    19:45   0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrloggername=pop3d-ssl -maxprocs=40 -maxperip=4 -pid=/var/run/pop3d-ssl.pid -nodnslookup -noidentlookup 995 /usr/bin/couriertls -server -tcpd /usr/sbin/pop3login /usr/lib/courier-imap/authlib/authpsa /usr/bin/pop3d Maildir
root       544  0.0  0.0   4064   600 ?        S    19:45   0:00 /usr/sbin/courierlogger pop3d-ssl
root       622  0.0  0.1  51656  2412 ?        Ss   19:45   0:01 /usr/libexec/postfix/master
postfix    630  0.0  0.1  51804  2508 ?        S    19:45   0:01 qmgr -l -t fifo -u
named      871  0.0  0.8 389428 18120 ?        Ssl  19:45   0:00 /usr/sbin/named -u named -c /etc/named.conf -u named -t /var/named/chroot
postfix    945  0.0  0.0 404416  1560 ?        Ssl  19:45   0:00 /usr/lib64/plesk-9.0/psa-pc-remote -p inet:12768@localhost
500       1000  0.0  0.1  61588  3792 ?        S    19:45   0:00 /usr/sbin/sw-cp-serverd -f /etc/sw-cp-server/config
root      1010  0.0  0.0 117208  1292 ?        Ss   19:45   0:00 crond
root      2037  0.0  0.9 332272 20556 ?        Ss   19:51   0:00 /usr/sbin/httpd
apache    2039  0.0  0.3 232192  6456 ?        S    19:51   0:00 /usr/sbin/httpd
postfix   2141  0.0  0.1  51716  2424 ?        S    19:55   0:00 tlsmgr -l -t unix -u
apache    2183  0.0  0.6 332556 13464 ?        S    19:57   0:00 /usr/sbin/httpd
apache    2193  0.0  0.6 332540 13132 ?        S    19:57   0:00 /usr/sbin/httpd
apache    2194  0.0  0.6 332568 13084 ?        S    19:57   0:00 /usr/sbin/httpd
apache    2196  0.0  0.6 332540 13100 ?        S    19:57   0:00 /usr/sbin/httpd
root      2784  0.0  0.0 106064  1460 ?        S    20:23   0:00 /bin/sh /usr/bin/mysqld_safe --datadir=/var/lib/mysql --socket=/var/lib/mysql/mysql.sock --pid-file=/var/run/mysqld/mysqld.pid --basedir=/usr --user=mysql
mysql     2913  0.0  1.0 494992 21052 ?        Sl   20:23   0:02 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
apache    2938  0.0  0.6 332548 13148 ?        S    20:24   0:00 /usr/sbin/httpd
root      3628  0.0  0.1 170560  3068 ?        S    21:00   0:00 CROND
root      3629  0.0  0.0   9196  1292 ?        Ss   21:00   0:00 /bin/bash /usr/share/clamav/freshclam-sleep
root      3631  0.0  0.0   4072   516 ?        S    21:00   0:00 sleep 8701
popuser   3782  0.0  0.0  11072  1080 ?        S    21:21   0:00 /usr/bin/imapd Maildir
popuser   3783  0.0  0.0  11072  1092 ?        S    21:21   0:00 /usr/bin/imapd Maildir
root      3785  0.0  0.1  34816  2624 ?        S    21:21   0:00 couriertls -localfd=4 -tcpd -server
root      3787  0.0  0.1  34816  2628 ?        S    21:21   0:00 couriertls -localfd=4 -tcpd -server
postfix   3810  0.0  0.1  51716  2296 ?        S    21:25   0:00 pickup -l -t fifo -u
root      3881  0.0  0.0  64120  1176 ?        Ss   21:36   0:00 /usr/sbin/sshd
root      3965  0.0  0.2 104472  4264 ?        Ss   21:42   0:00 sshd: root@pts/0
root      3969  0.0  0.0 110596  2072 pts/0    Ss   21:42   0:00 -bash
root      4072  0.0  0.2 104480  4428 ?        Ss   21:47   0:00 sshd: fantasma@pts/1
root      4074  0.0  0.0 110484  1956 pts/1    Ss+  21:47   0:00 -bash
root      4163  0.0  0.1  34816  2608 ?        S    22:02   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root      4164  0.0  0.1  34816  2608 ?        S    22:02   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
popuser   4169  0.0  0.0  11072  1084 ?        S    22:02   0:00 /usr/bin/imapd Maildir
popuser   4170  0.0  0.0  11072  1076 ?        S    22:02   0:00 /usr/bin/imapd Maildir
root      4192  0.0  0.1  34816  2608 ?        S    22:03   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
root      4193  0.0  0.1  34816  2604 ?        S    22:03   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
popuser   4194  0.0  0.0  11072   900 ?        S    22:03   0:00 /usr/bin/imapd Maildir
popuser   4195  0.0  0.0  11072  1108 ?        S    22:03   0:00 /usr/bin/imapd Maildir
root      4237  0.0  0.1  34816  2600 ?        S    22:09   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
popuser   4239  0.0  0.0  11072  1104 ?        S    22:09   0:00 /usr/bin/imapd Maildir
root      4250  0.0  0.1  34816  2596 ?        S    22:12   0:00 /usr/bin/couriertls -server -tcpd /usr/sbin/imaplogin /usr/lib/courier-imap/authlib/authpsa /usr/bin/imapd Maildir
popuser   4251  0.0  0.0  11072   900 ?        S    22:12   0:00 /usr/bin/imapd Maildir
postfix   4296  0.0  0.1  51712  2308 ?        S    22:19   0:00 anvil -l -t unix -u
10000     4310  1.2  0.0      0     0 ?        Z    22:22   0:00 [php-cgi] <defunct>
root      4313  1.0  0.0 110232  1136 pts/0    R+   22:22   0:00 ps aux
Any suggestion or idea what is happening??
Thanks,
Roberto.
