• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Problem with php
Thanks for the update Gedsta1....I am patiently waiting. Im done with manually changing settings on my production servers. They need to patch it....hopefully they figure it out soon.
Would be nice if they would acknowledge this post and update this themselves though.
I Solved this problem
I change to domain common php settings
method 1 (one domain)
Home>Subscriptions>domainname.com>general tab> click customize > select php settings tab
safe_mode select off (This setting is sufficient.)
method 2 (all domain)
Tools & Settings > Panle> Simple View Settings > Php Settings
Extra (for method 1 and 2)
No need the following. but I set myself.
safe_mode_exec_dir select custom value = c:\windows\temp
session.save_path select custom value = c:\windows\temp
display_errors select off
Mine is already set to that.
I tried this as well, and still the issues are there.
Glad you managed to fix it for yourself, but it definitely does not sort my issues out.
I cannot upload any images using the current CMS that we have, rendering it pointless.
So sick of seeing this message after trying to upload
Copy failed. (5005)
Works flawlessly on Plesk 10.0.1 - But broken on Plesk 10.4.4
I just tried this off another thread
PLEASE ADD AT THE PHP SETTING IN THE CONTROL PANEL AT OPEN_BASEDIR: \
just that
Will not work 100% well but at least your customers would be able to upload by PHP. until Parallels fix the issue.
And I can now upload to the CMS - Happy days.
That solution helps but is unsafe and increase the process in your server.
This may have another solution more secure and permanent but just setting Open_basedir = \ may fix this issues.
BUT AGAIN!
PARALLELS SHALL AMDE A KB ABOUT THIS ISSUE, HOW IS POSSIBLE NO OFFICIAL NOTICE OR KB ABOUT THIS ISSUE AND HOW TO FIX CORRECTLY.
NO EVERYONE IS A MASTER IN PHP OR SERVER ADMINISTRATION, THE IDEA TO HAVE A CONTROL PANEL IS MADE THINGS EASY NO HARDER.
Igor and Pavel in my point of view you guys are so irresponsible and shows the company policies at don't even shows up in this thread to at least give us options or answer any of the questions.
Things like this made people think switch!
I soon new panels will come and our loyalty would be compromised and I can tell I am talking for most of user and people use The Panel for windows.
Igor, Thanks for answer.
This post has this error but mine not.
http://forum.parallels.com/showthread.php?t=257412
Recreation:
1) Once the last update, the new domains or subscriptions add report error uploading.
cause: Open_basedir miss configuration.
Generic solution working at the moment, set at Open_basedir = \
All this configuration is made at the subscription personalized PHP setting subscription.
please review my post.
thanks
Parallels Plesk 10.4 for Windows
Windows 2008 RD x64
Issue: PhP Temporal directory permissions
Cause: Update Plesk 10.4
Diagnosis: Cannot upload files due TEMP folder do not allow open files or read files. this happens because each subscription has a PHP setting separately, happens when you create a new subscription or made any change to a old one to have customized PHP settings.
Temp folder error.
C:\Windows\Temp
Also I have try create a new folder: C:\Temp and give all permissions and inherent permissions but don't works neither.
Only solution so far until now working: setup at PHP Settings: Open_Basedir = \
Before the update all website has the access to upload files normally but after the update all uploads has been just stop.
Permissions and access rights to Temp folder are right.
Thank you. I have forwarded it to developers. I will update thread with results of investigation when I receive them.
Same here
Windows 2008 r2 x64
Same here problem here, amongst also completely ignoring the domains php version settings and many other things.
Release candidate my ar$£.
How I fixed it
Hey guys,
Just to let you know I had the same issue across all of my domains with Wordpress and solved it by editing the php.ini file. The file is located in "C:\Program Files (x86)\Parallels\Plesk\Additional\PleskPHP5\php.ini" there are two lines that refer to "C:\Windows\Temp" that need to be changed.
I created a temp folder at "C:\Temp" and set the permissions to "Full Control" for all of the plesk services/users. Then changed the two lines to that location in the php.ini file. After that it worked in all domains for all applications. :)
Hope it works for you guys
You can use following workaround:
Add Windows TEMP to open_basedir list in registry value, for example:
HKEY_LOCAL_MACHINE\SOFTWARE\[Wow6432Node]\PHP\Per Directory Values\C\Inetpub\vhosts\<domain>\httpdocs
open_basedir=C:\Inetpub\vhosts\<domain>\httpdocs\;c:\windows\temp\
or in Plesk GUI, domain PHP Settings. For example:
{DOCROOT}\;c:\windows\temp\
almost a year later - no fix for this?
I have just set-up a Wordpress site and get the same errors as originally mentioned at the top of this thread.
I find it incredible that after almost a year Parallels have not issued a patch/fix for this.
Is this normal?
