Question Problem with Update Plesk and System Package
andreagr
Hi, i've a Plesk 17.0.17 with update #30.
From some days i've the error on plesk autoupdate :
Execution failed.
Command: autoinstaller
Arguments: Array
[0] => --select-product-id
[1] => plesk
[2] => --select-release-current
[3] => --upgrade-installed-components
[4] => --include-components-from-class
[5] => aspect=panel
Details: WARNING: Ignored deprecated parameter in Plesk Installer's configuration file: 'SOURCE_TYPE' = 'network'
BUSY: Update operation was locked by another update process.
If i check with ps aux | grep install
i've two process:
root 9130 0.0 0.0 140460 19300 ? S 14:54 0:00 /usr/local/psa/admin/bin/autoinstaller --service-mode --enable-xml-output --ssl-cert /usr/local/psa/admin/conf/httpsd.pem --branch release,stable --web-interface --with-ssl --disable-browser
root 9131 0.0 0.0 112988 3352 ? S 14:54 0:00 /usr/local/psa/admin/bin/autoinstaller --service-mode --enable-xml-output --ssl-cert /usr/local/psa/admin/conf/httpsd.pem --branch release,stable --web-interface --with-ssl --disable-browser
But if i want to update the system with yum update this is the error:
Plugin enabled:fastestmirror
Lock /var/run/yum.pid attivo: another process in block with pid 3984.
Other Application ?: pum_worker
Memory : 38 M RSS (911 MB VSZ)
Start: Wed Aug 16 12:03:14 2017 - 3:19:48
Status : Waitins, pid: 3984
If i do
ps aux | grep pum
root 3984 0.0 0.0 932736 38576 ? S 12:03 0:00 /usr/bin/python -Estt /usr/local/psa/admin/sbin/pum_worker --simulate --json -- bind bind-libs bind-utils ca-certificates cups-libs glibc glibc-common glibc-devel glibc-headers httpd httpd-tools initscripts mod_ssl nss nss-sysinit nss-tools plesk-php70 plesk-php70-bcmath plesk-php70-cli plesk-php70-dba plesk-php70-enchant plesk-php70-fpm plesk-php70-gd plesk-php70-imap plesk-php70-intl plesk-php70-ldap plesk-php70-mbstring plesk-php70-mcrypt plesk-php70-mysql plesk-php70-odbc plesk-php70-opcache plesk-php70-pdo plesk-php70-pear plesk-php70-pgsql plesk-php70-process plesk-php70-pspell plesk-php70-snmp plesk-php70-soap plesk-php70-tidy plesk-php70-xml plesk-php70-xmlrpc procps selinux-policy selinux-policy-targeted sudo
what is this process?
It's safe to force kill it?
I can't update anything.
Thanks
Hi andreagr,
Pls. note, that this is JUST a warning and nothing which could prevent the update/upgrade procedure.
But...
... states quite clear, that there is another process running, which prevents the usage of another "autoinstaller" - instance. Pls. read and follow for example:
Both processes shoudl be killed
Yes! Otherwise, Plesk wouldn' t recommend the "killing" at the above mentioned KB - article.​
I've follow the kb but when execute strace i've this output:
Process 9130 attached
restart_syscall(<... resuming interrupted call ...>) = 0
poll([{fd=7, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 1000) = 0 (Timeout)
poll([{fd=7, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 1000^CProcess 9130 detached
<detached ...>
[root@server2 ~]# strace -p 9131
Process 9131 attached
read(12,
So the first is stucked but the second process no.. is safe to kill both process?
Ok i've kill all process and all process for yum.
I've done yum clean all and yum update.
But the shell is:
yum update
Freeing read locks for locker 0x1c7: 26279/140657389889280
Freeing read locks for locker 0x1c8: 26279/140657389889280
Freeing read locks for locker 0x1c9: 26279/140657389889280
Freeing read locks for locker 0x1ca: 26279/140657389889280
Freeing read locks for locker 0x1cb: 26279/140657389889280
Plugin abilitati:fastestmirror
Impostazione processo di aggiornamento
Determining fastest mirrors
epel/metalink | 19 kB 00:00
* base: fr.mirror.babylon.network
* epel: fr.mirror.babylon.network
* extras: fr.mirror.babylon.network
* updates: fr.mirror.babylon.network
and nothing appears.
The link fr.mirror.babylon.network is reachable from the server but I can't update centos 6.
Hi andreagr,
This could indicate a lack of memory at your server/vps. Consider to resolve this first, before you continue with any update/upgrade procedure.
( One solution could be to shut down services with lots of memory usage. Try to shut down one service after the other and keep trying to upgrade/update afterwards - after a successfull "yum" update/upgrade, pls. don't forget to restart the manually shut down services )
