Take alook at php.net regarding this function:
http://php.net/manual/en/function.strlen.php
It seems that there are difference between 5.2.x and 5.3.x for this function. Here is an explaination regarding this issue:
We just ran into what we thought was a bug but turned out to be a documented difference in behavior between PHP 5.2 & 5.3. Take the following code example:
<?php
$attributes = array('one', 'two', 'three');
if (strlen($attributes) == 0 && !is_bool($attributes)) {
echo "We are in the 'if'\n"; // PHP 5.3
} else {
echo "We are in the 'else'\n"; // PHP 5.2
This is because in 5.2 strlen will automatically cast anything passed to it as a string, and casting an array to a string yields the string "Array". In 5.3, this changed, as noted in the following point in the backward incompatible changes in 5.3 (
http://www.php.net/manual/en/migration53.incompatible.php):
"The newer internal parameter parsing API has been applied across all the extensions bundled with PHP 5.3.x. This parameter parsing API causes functions to return NULL when passed incompatible parameters. There are some exceptions to this rule, such as the get_class() function, which will continue to return FALSE on error."
So, in PHP 5.3, strlen($attributes) returns NULL, while in PHP 5.2, strlen($attributes) returns the integer 5. This likely affects other functions, so if you are getting different behaviors or new bugs suddenly, check if you have upgraded to 5.3 (which we did recently), and then check for some warnings in your logs like this:
strlen() expects parameter 1 to be string, array given in /var/www/sis/lib/functions/advanced_search_lib.php on line 1028
If so, then you are likely experiencing this changed behavior.
