Issue Problems due to temporary directory problem
BRAHM
Basic Pleskian
I am facing problems to upload files trough my php sites and to update WP sites.
the common error message is:
The package could not be installed. PCLZIP_ERR_MISSING_FILE (-4) : Missing archive file \TMP/akismet.tmp
I have tried to free some space of my server and I have run these lines.. would be them caused the problem?
#rm -rf /tmp/*
#rm -rf /usr/local/psa/tmp/*
#rm -rf /usr/local/psa/PMM/tmp/*
  1. Specify a new temporary folder going to Domains > example.com > File Manager > wp-content and create a new directory named TEMP
  2. Open the /var/www/vhosts/example.com/httpdocs/wp-config.php file and enter the following line at the bottom:
    define('WP_TEMP_DIR', ABSPATH . 'wp-content/TEMP');
Hi IgorG,
I have tried this but my other sites in codeigniter the file upload is facing the same problem.
I have edit php.ini in Tools and preferences and I have set up by my own the directive upload_tmp_dir to /tmp
and it solved for WP and Codeigniter sites hosted.
For some reason when I try to edit again php.ini file trought plesk the file get empty, why?
