Problems with installation Sugarcrm
RaulGG
Hi all,
to see if I can help. I am trying to install Sugarcrm v. 6.5.16 and then modify the permissions to the folders, I jump to the next step, but my screen is blank and will not let me do anything.
What can happen? How can I fix this?
I hope someone can help me.
Greetings!
Hi Raul,
You will need to see the error log for the exact PHP related errors (as I see most likely your display_errors is off). Optionally, from your control panel, you can enable display_errors and then you will see the exact error causing the halt in the installation!
Hi Raul,
Hello,
firstly thanks for your quick attention. Then I let the error that is giving me php.
thanks
Warning: require_once(modules/DynamicFields/DynamicField.php): failed to open stream: Permission denied in cursat.com/crm.cursat.com/data/SugarBean.php on line 48 Fatal error: require_once(): Failed opening required 'modules/DynamicFields/DynamicField.php' (include_path='.:') in cursat.com/crm.cursat.com/data/SugarBean.php on line 48
Hello again
Now I have another problem with Sugarcrm, and that is that you have created folders and puts the user is apache and I can not change the properties of the same.
What I have to do?
Thanks again,
You can change the permissions and ownership through SHELL by running the command:
Code:
chown -R <user>:psacln folder
You can get the user by
Code:
ls -l /var/www/vhosts/domain.com/httpdocs/*
Code:
Code:
Hello,
thank you very much for your help. In the end I managed to change the folder and change the permissions to install sugarcrm on my server.
Already running all ok, greeting
