Issue run-parts: /etc/cron.daily/60sa-update exited with return code 4
remy
Basic Pleskian
I get this error message in a mail with subject "Cron <root@dev2> test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )"
This file looks like this:
#!/bin/bash
### Copyright 1999-2017. Parallels IP Holdings GmbH. All Rights Reserved.
sa_update()
/usr/bin/sa-update
local rc="$?"
case $rc in
# Only restart spamd if sa-update returns 0, meaning it updated the rules
0) env PATH=/opt/psa/admin/sbin:/usr/local/psa/admin/sbin:$PATH spammng --condrestart ;;
# If sa-update returns 1 then there are no updates
1) exit 0 ;;
esac
return $rc
sa_update >> /var/log/sa-update.log 2>&1
What is your Plesk version? Try to run this cron script manually and check output and log:
# sh /etc/cron.daily/60sa-update
# less /var/log/sa-update.log
Got the same error today.
Product version: Plesk Onyx 17.5.3 Update #37
Update date: 2018/01/10 13:29
Build date: 2017/03/17 16:00
OS version: Ubuntu 16.04
Revision: 55d1b49a272f44666e1920eca8b6e4da449a38cd
Architecture: 64-bit
Wrapper version: 1.2
When started manually, there's no feedback given on the console. The last couple of lines in the log file are these:
Service condrestart was done successfully.
gpg: process '/usr/bin/gpg' finished: exit 1
error: GPG validation failed!
The update downloaded successfully, but the GPG signature verification
failed.
channel: GPG validation failed, channel failed
channel: SHA1 verification failed, channel failed
After applying your fix
You can fix it with
# wget http://spamassassin.apache.org/updates/GPG.KEY
# sa-update --import GPG.KEY
another error arised:
2018-01-31 04:51:32] Spamassassin update started...
[2018-01-31 04:51:32] sa_update() function starting...
rules: failed to run FORGED_GMAIL_RCVD test, skipping:
(Can't locate object method "check_for_forged_gmail_received_headers" via package "Mail::SpamAssassin::perMsgStatus" at (eval 1317) line 1033.
channel: lint check of update failed, channel failed
(Can't locate object method "check_for_forged_gmail_received_headers" via package "Mail::SpamAssassin::perMsgStatus" at (eval 1317) line 71.
This issue appeared after one of the last Plesk microupdated
The issue was caused by Spam Assassin's bug #7540
Apply new rule set provided by SpamAssassin as a workaround:
[Apache-SVN] Revision 1822466
As the bug is on SpamAssassin's side, when SpamAssassin will release bugfix it will be added to repositories and issue will be fixed automatically after update.
I still have this in log :
Code:
failed.
