• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
samba fileserver problems
T
tony744
s anyone successfully using the samba fileserver module on plesk 8.0?
I am having a problem connecting to the server using samba.. Here is the problem...
On my XP computer I select windows explorer.. I click tools then Map a network drive... I enter:
\\server\share
At this point it appears that I am attaching to the server because I get a prompt for a username and password..
No matter what username and password I enter I am not allowed into the shared filesystem..
I look into the samba logs and get these errors from the logs...
[2006/06/09 17:42:27, 0] smbd/sesssetup.c:reply_sesssetup_and_X(586)
reply_sesssetup_and_X: Rejecting attempt at SPNEGO session setup when it was
not negoitiated.
Any one else having this problem..
:confused:
TJV
After much research here is what you need to do to get this to work... After you have configured the samba files server you must set up a VPN in order to connect using windows...
You will be able to connect local but not on a remote server..
I myself have not yet configured a vpn server..
