serious issue during attempted upgrade..
contents of that dir are:
00-sso-cpserver.conf hspc-httpd.conf.orig plesk.socket.sh
hspc-httpd.conf plesk.conf sso.socket.sh
I have received following developer's recommendation:
I have the same problem
but when i try and do autoinstaller it tells me that the latest is already installed
but psa is not running and i can'tget it to run with psa start either
I have the same problem. I did
/usr/local/psa/admin/sbin/autoinstaller --install-system-only --select-release-latest
and
autoinstaller --select-release-latest --upgrade-installed-components
and psa doesn't start.
centOS 5.5, upgrading from 10.1.1 to 10.2. I deleted proxy_ajp.conf in /etc/httpd/conf.d/ in order to at least web sites working..
In application.d I have the same files than exposed above, and no 13 line in /etc/sw-cp-server/config
help please!
I am also in a similar situation, currently totally unable to see CP through web browser.
Have tried to update 10.1 to 10.2 with the following error:
# /usr/local/psa/admin/sbin/autoinstaller --select-release-id PLESK_10_2_0 --upgrade-installed-components
File downloading products.inf3: 100% was finished.
File downloading plesk.inf3: 10%..20%..30%..40%..50%..61%..70%..81%..90%..100% w as finished.
File downloading ppsmbe.inf3: 10%..20%..39%..49%..59%..68%..88%..100% was finish ed.
File downloading sitebuilder.inf3: 21%..33%..57%..70%..82%..100% was finished.
File downloading sso.inf3: 22%..48%..73%..86%..100% was finished.
File downloading setemplates.inf3: 41%..88%..100% was finished.
File downloading pp-sitebuilder.inf3: 19%..42%..64%..86%..100% was finished.
File downloading billing.inf3: 15%..33%..42%..50%..68%..86%..100% was finished.
Checking for installed packages...
File downloading PSA_10.2.0/plesk-10.2.0-cos5-x86_64.inf3: 10%..20%..30%..40%..5 0%..60%..70%..80%..90%..100% was finished.
File downloading PSA_10.2.0/plesk-patches-10.2.0-all.inf3: 11%..26%..41%..56%..8 6%..100% was finished.
File downloading SITEBUILDER_5.2.0/sitebuilder-5.2.0-rhall-all.inf3: 63%..100% w as finished.
File downloading BILLING_10.2.0/billing-10.2.0-rhall-all.inf3: 100% was finished .
Detecting installed product components.
Retrieving information about the installed packages...
File downloading SITEBUILDER_5.2.0/update-rpm-RedHat-all-all/update-5.2.0-rhall- all.hdr.gz: 100% was finished.
File downloading BILLING_10.2.0/update-rpm-RedHat-all-all/update-10.2.0-rhall-al l.hdr.gz: 100% was finished.
File downloading SITEBUILDER_5.2.0/thirdparty-rpm-RedHat-all-all/thirdparty-5.2. 0-rhall-all.hdr.gz: 100% was finished.
File downloading SITEBUILDER_5.2.0/dist-rpm-RedHat-all-all/build-5.2.0-rhall-all .hdr.gz: 11%..20%..31%..40%..50%..60%..70%..80%..91%..100% was finished.
File downloading BILLING_10.2.0/dist-rpm-RedHat-all-all/build-10.2.0-rhall-all.h dr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..91%..100% was finished.
File downloading BILLING_10.2.0/thirdparty-rpm-RedHat-all-all/thirdparty-10.2.0- rhall-all.hdr.gz: 100% was finished.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/build-10.2.0-cos5-x86_64.hd r.gz: 10%..20%..30%..40%..50%..60%..71%..80%..90%..100% was finished.
File downloading PSA_10.2.0/update-rpm-CentOS-5-x86_64/update-10.2.0-cos5-x86_64 .hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_10.2.0/thirdparty-rpm-CentOS-5-x86_64/thirdparty-10.2.0-cos 5-x86_64.hdr.gz: 11%..23%..32%..41%..53%..65%..71%..83%..92%..100% was finished.
Determining the packages that need to be installed.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/plesk-core-10.11.0-cos 5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/plesk-l10n-10.11.0-cos 5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-10.2.0-cos5.build1 011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-libpam-plesk-10.11 .0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match .
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-mod-fcgid-configur ator-2.0.0-cos5.build1011110330.18.x86_64.rpm: was skipped because of md5 checks um match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-mod_fcgid-2.3.5-11 021819.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-triggers-10.11.0-c os5.build1011110331.11.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-updates-10.2.0-cos 5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/base/psa-vhost-10.11.0-cos5 .build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/updater/psa-autoinstall er-3.9.0-110316.15.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/migration/psa-migration -agents-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
Snip as to long
Snip continued
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/migration/psa-migration -manager-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Class-Inspecto r-1.24-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Convert-BinHex -1.119-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Digest-SHA-5.4 8-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Error-0.17016- 10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-FCGI-0.71-1012 0713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-File-Temp-0.22 -10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-IO-stringy-2.1 10-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Log-Log4perl-1 .28-11021518.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-MIME-tools-5.4 28-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-MailTools-2.02 -10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Net-IDN-Encode -1.100-11022213.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Net-IDN-Namepr ep-1.100-11022213.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Params-Validat e-0.89-10120712.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Pod-WSDL-0.05- 10122810.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-SOAP-Lite-0.71 2-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Text-Template- 1.44-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-Unicode-String prep-1.103-11022213.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-XML-Filter-Buf ferText-1.01-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-XML-Validator- Schema-1.10-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/perl-XML-Writer-0.6 11-10120713.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/pba/plesk-billing-plugi ns-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checks um match.
File downloading SITEBUILDER_5.2.0/dist-rpm-RedHat-all-all/base/pp-sitebuilder-5 .2.0-34849.11032401.noarch.rpm: was skipped because of md5 checksum match.
File downloading SITEBUILDER_5.2.0/dist-rpm-RedHat-all-all/base/pp-sitebuilder-d efault-templates-5.2.0-34849.11032401.noarch.rpm: was skipped because of md5 che cksum match.
Snip 2
Snip continued
File downloading SITEBUILDER_5.2.0/dist-rpm-RedHat-all-all/base/pp-sitebuilder-s kins-5.2.0-34849.11032401.noarch.rpm: was skipped because of md5 checksum match.
File downloading BILLING_10.2.0/dist-rpm-RedHat-all-all/packages/plesk-billing-1 0.2.0-20110331.12.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/bw/mod_bw-0.8-10120712. x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/modules/firewall/psa-fi rewall-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 ch ecksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/sshterm/SSHTerm-0.2.2-1 0.11030318.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/modules/watchdog/psa-wa tchdog-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/mailman/psa-mailman-con figurator-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/mail/psa-spamassassin-1 0.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checksum m atch.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/backup/psa-backup-manag er-10.11.0-cos5.build1011110331.11.x86_64.rpm: was skipped because of md5 checks um match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/backup/psa-ftputil-2.1. 1-1.10120712.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-horde-3.3.10- cos5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-imp-4.3.9-cos 5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-ingo-1.2.5-co s5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-kronolith-2.3 .5-cos5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match .
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-mimp-1.1.3-co s5.build1011101207.12.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-mnemo-2.2.4-c os5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-passwd-3.1.3- cos5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
File downloading PSA_10.2.0/dist-rpm-CentOS-5-x86_64/opt/horde/psa-turba-2.3.5-c os5.build1011110330.18.noarch.rpm: was skipped because of md5 checksum match.
Starting installation of packages
Changing shell for popuser.
Shell not changed.
Changing shell for mhandlers-user.
Shell not changed.
config updated
===> Updated /etc/psa/psa.conf
===> Preparing upgrade
Stopping psa... done
Stopping mail handlers tmpfs storage
psa is stopped
===> Cumulative database upgrade has been started
===> Upgrade completed.
ERROR: Unable to install the "perl-SOAP-Lite-0.712-10120713.x86_64" package.
Not all packages were installed.
Please, contact product technical support.
Will look around the forum more but been trying to fix this for hours now :(
Worst this is although I have kept all the websites going there is no email and my customers are going nuts at me!
Hope there is a work around soon.
Here is the contents of my /etc/sw-cp-server/config file:
server.modules = ()
server.document-root = "/dev/null"
server.port = 10001
server.bind = "127.0.0.1"
server.pid-file = "/var/run/sw-cp-server.pid"
server.errorlog-use-syslog = "disable"
server.errorlog = "/var/log/sw-cp-server/error_log"
server.username = "sw-cp-server"
server.groupname = "sw-cp-server"
include_shell "/usr/share/sw-cp-server/applications-conf.sh"
Wondered if beamerboyle knew what support did to aid his install which was falling over with the same ERROR: Unable to install the "perl-SOAP-Lite-0.712-10120713.x86_64" package.
Have just tried again using:
run upgrade via /usr/local/psa/admin/sbin/autoinstaller --install-system-only --select-release-latest
Resulting in the same error :(
Update,
Been banging away at this all day!
Did a bit a searching around the server files and found part of my system still refereed to PSA being 10.0.0 version?
So did manual upgrade routine:
/usr/local/psa/admin/bin/autoinstaller
Select options, upgrade failed with database error due to version conflict stating it was 10.8.0 ?
So did following
/usr/local/psa/bootstrapper/pp10.9.0-bootstrapper/bootstrapper.sh repair
and just for good measure
/usr/local/psa/bootstrapper/pp10.10.1-bootstrapper/bootstrapper.sh repair
Now try update again
/usr/local/psa/admin/sbin/autoinstaller --select-release-latest --upgrade-installed-components
Now get erorrs
I have the same files as above giving error on 13 line in /etc/sw-cp-server/config and also /usr/share/sw-cp-server/application-config.sh
So what to do, well simply renamed both .old
EXAMPLE: config.sh.old and config.old
Now rerun update
Install/update now working as expected, it will complain that it cannot start sw-cp-server and that's to be expected, once finished try the following just for confirmation purposes.
/etc/init.d/psa start
This should now show
Starting psa... failed
Starting xinetd service... done
Starting named service... done
Starting mysqld service... done
Starting postgresql service... done
Starting psa-spamassassin service... done
Plesk: Starting Mail Server... already started
Starting mail handlers tmpfs storage
That's great, now go back and rename both config.sh.old and config.old to
config.sh and config respectively
Once done restart PSA
Starting psa... done
Happy times :) Off for a long sleep!
Tried it but it didn't work for me.
i had to
/usr/local/psa/bootstrapper/pp10.11.0-bootstrapper/bootstrapper.sh repair
and
/etc/sw-cp-server/config and also /usr/share/sw-cp-server/applications-conf.sh
really need help on this, none of my websites or anything are working :(
i used this command
then went to restart sw-cp-server
and still getting stale pidfile [FAILED]
how do i fix this??
What sort of errors you have in /var/log/sw-cp-server/error_log after restarting sw-cp-server?
Once again - What sort of errors you have in /var/log/sw-cp-server/error_log after restarting sw-cp-server?
Code:
2011-04-27 19:25:12: (log.c.75) server started
2011-04-27 19:31:06: (log.c.135) server stopped
2011-04-27 19:31:06: (log.c.75) server started
2011-04-27 19:32:40: (log.c.135) server stopped
2011-04-27 19:32:40: (log.c.75) server started
2011-04-27 19:32:44: (log.c.135) server stopped
2011-04-27 19:32:44: (log.c.75) server started
2011-04-27 19:33:01: (log.c.135) server stopped
2011-04-27 19:33:02: (log.c.75) server started
2011-04-27 19:37:10: (log.c.135) server stopped
2011-04-27 19:37:10: (log.c.75) server started
2011-04-27 19:38:36: (server.c.1266) [note] graceful shutdown started
2011-04-27 19:38:37: (log.c.135) server stopped
2011-04-27 19:38:38: (log.c.75) server started
2011-04-27 19:40:21: (connections.c.299) SSL: 1 error:140780E5:SSL routines:SSL23_READ$
2011-04-27 19:40:21: (connections.c.299) SSL: 1 error:1407609C:SSL routines:SSL23_GET_$
2011-04-27 19:40:21: (connections.c.299) SSL: 1 error:140760FC:SSL routines:SSL23_GET_$
2011-04-27 19:40:26: (connections.c.299) SSL: 1 error:140780E5:SSL routines:SSL23_READ$
2011-04-27 19:40:26: (connections.c.299) SSL: 1 error:140940E5:SSL routines:SSL3_READ_$
2011-04-28 09:41:26: (connections.c.299) SSL: 1 error:14094418:SSL routines:SSL3_READ_$
2011-04-28 09:41:26: (connections.c.299) SSL: 1 error:140940E5:SSL routines:SSL3_READ_$
2011-04-28 09:49:25: (log.c.135) server stopped
2011-04-28 09:51:01: (log.c.75) server started
dnsmng: ^^W^Oá: invalid IP address
dnsmng: Õû¼^Ã^^W^Oá: invalid IP address
dnsmng:  ^AAÃ: invalid IP address
2011-04-28 10:00:14: (log.c.135) server stopped
2011-04-28 10:00:14: (log.c.75) server started
2011-04-28 10:01:38: (log.c.135) server stopped
2011-04-28 10:01:38: (log.c.75) server started
2011-04-28 10:01:38: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:02:26: (log.c.75) server started
2011-04-28 10:02:26: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:15:08: (log.c.75) server started
2011-04-28 10:15:08: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:32:06: (log.c.75) server started
2011-04-28 10:32:06: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:32:07: (log.c.75) server started
2011-04-28 10:32:07: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:32:09: (log.c.75) server started
2011-04-28 10:32:09: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:36:11: (log.c.75) server started
2011-04-28 10:36:11: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
2011-04-28 10:36:12: (log.c.75) server started
2011-04-28 10:36:12: (network.c.345) SSL: error:140E6118:SSL routines:SSL_CIPHER_PROCE$
this is my log as it stands now
NVM, wiped it and followed instructions for pci v10
also noticed that on the website, where the ciphers are it has a space instead of a :
this might be why mine failed
My sollution to this problem
I have had the same issue upgrading from Plesk 9.5.4 to 10.2.0.
I used the autoinstaller to upgrade. The first upgrade gave me the forementioned error:
Removing this package solved the dependency problem and the upgrade then worked up to the point where psa wouldn't start with error:
Restarting SWsoft control panels server... Duplicate config variable in conditional 0 global: var.sso_username
2011-04-10 00:26:20: (configfile.c.838) source: /usr/share/sw-cp-server/applications-conf.sh line: 72 pos: 11 parser failed somehow near here: (EOL)
2011-04-10 00:26:20: (configfile.c.838) source: /etc/sw-cp-server/config line: 13 pos: 1 parser failed somehow near here: (EOL) failed
Failed. Can not restart web server.
After a day of digging i found that there were two sw-sso packages installed:
sw-sso-2.3-10092418
sw-sso-2.6-11033111
A simple rpm -e sw-sso-2.3-10092418 did the trick. No new installation, psa now starts without a problem.
I don't use sso so i'm not sure to what extent the single sign-on still works but at least the plesk interface is up again.
Hope this helps some others!
Solution
The problem lies with the fact that there is a conflict between the perl-SOAP-Lite version being deployed and the one already installed.
To get around it, I uninstalled the old one, installed the new one and re-ran the Plesk upgrade. To uninstall, though, you might need to be fairly destructive with the dependency check. This is what I did to get my control panel back up and running:
rpm -e --nodeps perl-SOAP-Lite-0.712-10102009.x86_64
wget http://autoinstall.pp.parallels.com.../pba/perl-SOAP-Lite-0.712-10120713.x86_64.rpm
rpm -ihv perl-SOAP-Lite-0.712-10120713.x86_64.rpm
/usr/local/psa/admin/bin/autoinstaller --select-release-latest --upgrade-installed-components
All is fine in the world again even though it was a little frustrating to have to do this at all.
BTW - Running CentOS 2.6.18-164.11.1.e15 kernel, fwiw
