S
SpidermonBob
I am quite confused and can't find specific information anywhere.
When I purchased PleskPlus & SiteBuilder for a newly configured Debian server and had it installed by SWsoft. I then received a notice that the installation was complete...
>SiteBuilder was installed successfully. Do not forget to
> make changes to the DNS records of your server so that
> the domain name http://sitebuilder.www
> points to this server.
> SiteBuilder has three entry points:
> http://sitebuilder.www/admin/index.php
> Administrator's entry point
> http://sitebuilder.www/wizard/index.php
> Guest entry point. Place this link on your site and use
> it for advertizing purposes.
> http://sitebuilder.www/sitelogin.php
> Regular entry point.
> To configure registered users login options,
> please refer to the documentation
> * Default administrator's login is 'root' *
> * Default administrator's password is 'sitebuilder' *
...I logged into Plesk via IP# and started to examine the new environment. I started assigning IPs, clients, and domains. Every time I tried to access a newly added domain by its IP# I got no response. I originally thought that the problem had to do with DNS since I couldn't reassign the domain for the server since it was being used on the old server. For weeks I went crazy only to learn that none of the other IP#s had their ports opened. I again tried to get some serious work done and assigned each newly added domain as its own DNS. After moving over my main domain and setting up its DNS I tried evoking SiteBuilder again by the above instructions. I then realized that I had to do something with SiteBuilder and DNS. I made changes to the DNS records of the server so to add
sitebuilder.www.MYDOMAIN.COM. as an A record. After the zone files propagated I tried again only to realize that I couldn't login. I then read a post that I needed to use (admin / admin) not (root / sitebuilder).
For a little while I thought I had SiteBuilder Working I could access the admin area by going to
http://sitebuilder.[url]www.MYDOMAIN.COM/admin/index.php[/url]
http://sitebuilder.[url]www.MYDOMAIN.COM/wizard/index.php[/url] The page came up but I could not get to step 1.
Since looks stupid I went back to DNS to remove the www since http://sitebuilder.MYDOMAIN.COM at least looks reasonable. After waiting for the correction to prorogate I again tried to access SiteBuilder I got errors at the control panel and could no longer access the admin pages. I reread all the documentation but something seems to be missing...
Does anyone know exactly how I should setup DNS (preferably for websites/MYDOMAIN.COM rather than sitebuilder.MYDOMAIN.COM)?
Also how do I setup SiteBuilder for my other domains and the domains of my clients?
...I also noticed in PHP Version 4.3.10-18 that
Virtual Directory Support is disabled
register_globals is set to Off Off
do these, above, settings have anything to do with my problem and some of the errors I get on installing some of the programs in the ApplicationVault?
Any assistance with these issues would be extremely helpful.
Thanks...
Thanks...
