Resolved Warning about in.proftpd: is it a problem?
MMagnani
Hello,
After some server uptime, dmesg command shows in last line:
[11615.673060] capability: warning: `in.proftpd' uses 32-bit capabilities (legacy support in use)
FTP seems to work fine, Debian 8.7‬, Plesk Onyx Version 17.0.17 Update #18
Could someone please explain if this is a problem?
Thanks in advance!
Hi MMagnani,
since you seem to think, that even on a "fresh installation", there can't be any "old" libraries, let's have a look to your current installation then:
Code:
apt-cache policy libcap2
apt-cache policy libcap2-dev
apt-cache policy libcap-dev
Thank you, UFHH01
I am so far from being an expert, just trying some uneducated common sense. I am sorry if my questioning sounds rude.
Code:
# apt-cache policy libcap2
libcap2:
  Installed: 1:2.24-8
  Candidate: 1:2.24-8
  Version table:
 *** 1:2.24-8 0
        500 http://ftp.debian.org/debian/ jessie/main amd64 Packages
        100 /var/lib/dpkg/status
# apt-cache policy libcap2-dev
libcap2-dev:
  Installed: (none)
  Candidate: (none)
  Version table:
# apt-cache policy libcap-dev
libcap-dev:
  Installed: (none)
  Candidate: 1:2.24-8
  Version table:
     1:2.24-8 0
As so, could you please explain me if above capability warning means any problem or risk and, if yes, how to solve it?
Thank you!
Hi MMagnani,
how to solve it?
hm... let me quote the answer from the provided link from @Peter Debik :
Question: Why do I see the following in my system logs?
warning: `proftpd' uses 32-bit capabilities (legacy support in use)
Answer: This warning is coming from the use of the libcap library. A newer version of the libcap library (called the "libcap2" or "libcap2-dev" package on some Linux distributions) is now available.
To remove the above warning, you will need to update/install the newer libcap2 or libcap2-dev package on your system, and re-build proftpd (using version 1.3.2rc1 or later) in order to compile and link against the newer libcap library.
Investigations:
=> https://packages.debian.org/de/jessie/proftpd-basic ( = proftpd-basic (1.3.5-1.1+deb8u1) ) => => => as you can see, the answered requirements "version 1.3.2rc1 or later" are already met. ;)
libcap2: Installed: 1:2.24-8
Candidate: 1:2.24-8
But ( ! ) => https://launchpad.net/debian/+source/libcap2/+changelog states, that libcap2 version "2.25-1" was only published to Debian "Stretch" and "Sid" ( pls. see => https://launchpad.net/debian/+source/libcap2/1:2.25-1 ).​
Now looking for libcap-dev and libcap2-dev:
=> https://packages.debian.org/en/jessie/libcap-dev ( version 2.24-8 )
=> https://packages.debian.org/en/jessie/libcap2-dev ( Packages providing libcap2-dev => libcap-dev )
Conclusion: Is it WORTH to eliminate the warning by compiling and installing the newer, actual libcap2 - version 2.25-1 ???
Well, it's up to you, MMagnani.
Just be informed, that this "warning" doesn't harm your system, nor does it lead to issues/problems/failures with ProFTPD, as you already noticed. Some Linux distributions have a newer version, some don't... at the moment, Debian jessie works with 2.24-8, Ubuntu 16.04 with 2.24-12 and CentOS 7 comes with version 2.22-8 . The "warning" informs you as well, that is uses "32-bit capabilities (legacy support in use)"... but if you insist to compile and install the newest libcap2 - version, in order to get rid of that warning, pls. feel free to do that extra work. :)
