Backups to remote storage fail with "expected str, bytes or os.PathLike object, not int"
ahoi
Basic Pleskian
Username:
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
18.0.47, Debian 11
PROBLEM DESCRIPTION
Backups to remote storage (FTPS) are failing instantly with "expected str, bytes or os.PathLike object, not int".
Could be related to PPPM-13733.
STEPS TO REPRODUCE
Create a new backup task with remote store target.
ACTUAL RESULT
Backup fails with
Fehler: Der Backupvorgang ist fehlgeschlagen: expected str, bytes or os.PathLike object, not int
EXPECTED RESULT
Working backup
ANY ADDITIONAL INFORMATION
(DID NOT ANSWER QUESTION)
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
Hello @ahoi + Plesk team,
the new update release did not solve the problem mentioned in this bug report. It does still exist.
In our case we are using remote SFTP storage.
Server 1:
"Exclude log files" is active
"Exclude specific files from the backup" is deactivated
Server 2:
"Exclude specific files from the backup" is active
Both servers fail to run the nightly backups:
The following errors occurred during the scheduled backup process:
I'm using the backup schedule using as amazon s3 storage and it's returning the following error:
I have Plesk updated to the latest version:
Version 18.0.47 Update #1
Same Thing when I have tried to do a backups
After then, I have received the same occured
BUT
I have tried another time, directly in the Plesk Interface, Backup, and now it seems to work
But I have erased all backup pfff :(
I'll keep you informed after one day, after the Auto Backup has working
I really wonder how it is possible that such an important core feature can be broken with a new Plesk release. Even the following patch release, that was dealing with another backup issue, did not handle that obvious bug. It feels like Plesk does not have a proper (automatic) unit / functional / system testing before new releases are published. For many Plesk clients backups are part of their SLAs to their own clients. This is more than a warning to everyone to disable automatic Plesk panel updates.
Automatic Mode not working : ( Snif
But yerstaday I have done a complete backup but manually
Grrr
Les erreurs suivantes se sont produites pendant le processus de sauvegarde planifiée :
same issue here
Plesk Obsidian 18.0.47 Update #1
job: Backup split with exclusions full backup and also incremental
Manual start with identical parameters also aborts
same issue here
Automatic update to
Plesk Obsidian Version 18.0.47 Update #2
is done. With the latest update the error seems to be fixed. Backup ran error-free and successfully. Thanks!
