DNS Slave configuration Problem
isomonkpiss
Basic Pleskian
Hello,
i hope someone can help me..
i m trying to configure a webmin vps as a slave zone for a secondary nameserver, master is plesk (12.5)
i followed this guide: nameservers are pointing: ns1 to plesk server and ns2 to webmin vps
https://talk.plesk.com/threads/guide-on-setting-up-master-secondary-dns-servers.288500/
i added the webmin vps ip to the Transfer Restrictions Template, changed ns2 IP in DNS Records of Domain targeting to webmin vps, firewalls are disabled but i get the following error in dnscheck
Name server ns2.domain.com (xxx.xxx.xxx.xxx) not authoritative for domain.com
and
At least one name server failed to respond in a timely manner
Failure detail: xxx.xxx.xxx.xxx
what can i do
Hi @isomonkpiss
Do you have a NS record for each nameserver in the zone for domain.com? If not, that could be why you are getting the "not authoritative" error when running a DNS check.
What happens if you run this command from the command line (replacing domain.com for the actual domain name):
Code:
dig domain.com @ns2.domain.com
Do you get a reply or a failure?
hello chris.. thank you for your help now i get a replay. it looks fine. my mistake was that i added ns2.domain.con as as slave dns in webmin and not domain.com
now i have another Prob.
when i press on Test Zone Transfer i get
Testing transfer of slave zone from MASTERIP ..
.. from MASTERIP : Completed OK
Test transfer successfully fetched 20 records from at least one nameserver. Actual transfers by BIND should also succeed
BUT
the slave Zone File still empty
This page shows the DNS records file /var/lib/bind/domain.com.hosts, created by BIND when the zone was transferred from the master server.
However the file is currently empty, probably because the zone has not yet been transferred from the master server
is something else i have to configure on slave? here is a screenshot
