Help with installing and uninstalling Sitebuilder
W
whitebox
i'm trying to uninstall and install Sitebuilder 2.0.
i have red hat 9 and plesk 7.5.3. i know sitebuilder 1 was installed in /user/local/sitebuilder and when i tried to install 2 it asked me to remove that firectory which i did.
after installing 2 system went crazy so i uninstalled 2.
now i'm trying to install it again, it gives me error that that rpm is already installed but /usr/local/sitebuilder is not there.
can someone help me how to deinstall 2.0 corectly
thanks
ok i got that fixed,
yum remove Sitebuilder and then install again
but now i have different problem.
i open my http://sitebuilder.mydomain.com it takes me to install page and then when i click ok to install it goes just to blank web page.
i tried every possibly account and password.
do i have to create database manual that would be one question and second does anyone know why is opening blank page ????
thanks
That is normality with sitebuilder.
I'm also sitting on my version 1.1.1 experiencing the same troubles. Just wait until the next bugfix comes out .....and try again.....and again....
Good luck and have patience
Bart
are you talking about that first post or second where nothing comes up after you click OK ?
