how to split different of control panel hosts
tong c
Basic Pleskian
a customer of our company has buy two host packages. with the same contact name, say, Jack. Although he has a usename and password respectively., when he use a usename and password log into the control panel, simultaneously, he can switch to another control panel of host. He want to do that every host can not switch to each other,because his two packages are used among different group,maybe his own customers. So I desire to wonder how to achieve it? my sincere thanks go to you in advanced.
can not split two hosts
Does plesk has this functionality? or it is enable to separate two hosts, but I know cpanel can split two hosts.
I don't understand clearly your question, however if you mean can a customer switch between 2 subscriptions if logged in, the answer is Yes if both of the subscriptions belong to the same customer.
