KnowledgeTree installation problem
L
lukaschemp
Hey,
I want install KnowledgeTree from Plesk and i get this:
* PHP support (>= 4.3.0, < 5.0) (available: 5.2.8, suitable: no)
* PHP safe mode off (available: off, suitable: yes)
* Database required (mysql, version >= 4.0) (available: 5.0.45, suitable: yes)
* Disk space required: 13.3 MB (available: 9 462 MB, suitable: yes)
My version of PHP is:
PHP 5.2.8 (cli) (built: Jan 5 2009 15:12:04)
so what's the problem?
Hey,
The problem is
Hey,
Just to re-iterate what sergius said. According to the above, the version of KnowledgeTree you have requires a version of PHP which is 4.3.0 or higher and lower than 5.0. 5.2.8 is not lower than 5.0, therefore it is refusing to install.
Your options are to downgrade your version of PHP (I wouldn't recommend this, especially on a server running Plesk), or use a newer version KnowledgeTree - the current version requires PHP 5.2.3 or higher.
