Issue Latest 'beta' feature to Plesk to upgrade Mariadb is giving problems
efisher@
Almalinux 9.3
18.0.58
I know I took a big risk to use the new beta feature in Plesk that juust released to upgrade my Mariadb instance to the latest, 10.11. All went well, but afterwards, Wordpress is no longer able to connect to 'localhost' for the database. If I change the DB_HOST to the host name or to 127.0.0.1 it works fine. I know that 'localhost' has a special meaning to MySQL derivatives, but not sure what would have changed between 10.5 and 10.11 to break Wordpress connecting to 'localhost'. This is on the latest update of Almalinux 9 on a very new server.
Anyone tried this out yet and anyone had any success or suggestions to offer?
Thanks,
-Eric
@efisher@ Please check /etc/my.cnf if it includes skip_name_resolve or skip-name-resolve = 1. If so, please try to comment these lines and reload MariaDB afterwards.
@efisher@ Thank you for the report! I'm able to reproduce the issue in our lab and we a working on this. I will inform you here as soon as we will find the root cause
As a preliminary result, the problem is related to SELinux as @danami wrote above.
Here are the details:
Connection using mysql client works, as well via mysqli_connect().
With debug:
AH01071: Got error 'PHP message: PHP Warning: mysqli_real_connect(): (HY000/2002): Permission denied in /var/www/vhosts/test1.10-69-45-63.qa.plesk/httpdocs/wp-includes/class-wpdb.php on line 1987'
So only mysqli_real_connect() fails for whatever reason
Disabling SELinux helps. In audit.log:
type=AVC msg=audit(1705071197.377:1479): avc: denied { connectto } for pid=11111 comm="php-fpm" path="/var/lib/mysql/mysql.sock" scontext=system_u:system_r:httpd_t:s0 tcontext=system_u:system_r:unconfined_service_t:s0 tclass=unix_stream_socket permissive=0
audit2allow:
#============= httpd_t ==============allow httpd_t unconfined_service_t:unix_stream_socket connectto
We continue our investigation.
@Peter Debik Not sure if this is related but there is a bug on newer versions of MariaDB/MySQL where it refuses connections to the socket with SELinux enabled. I've been tracking it and it doesn't look like the fix has made it's way to OS builds yet.
So a user might have socket connection issues after upgrading MariaDB/MySQL.
@dash Yes that's what I thought as it will connect using the socket when you use localhost. Unfortunately I couldn't see a quick easy fix without overriding the mariadb unit file like this:
The SELinux label on the socket seems to get set every time mariadb is restarted so I don't think that you can just re-label it with semanage. The real fix has been merged into the mysql-selinux package located here: https://bodhi.fedoraproject.org/updates/FEDORA-2023-2b65fa4f45
@efisher@
So, finally the root cause is an incompatibility between system and MariaDB SElinux policy.
We will deliver Plesk update to fix the policy and prevent future failures.
As a workaround, to fix the issue you can execute the following command as a root user in SSH terminal:
Code:
#chcon system_u:object_r:mysqld_exec_t:s0 /usr/sbin/mariadbd && systemctl restart mariadb.service
thanks for your report!
Google brought me here with "SELinux is preventing /opt/plesk/php/8.3/sbin/php-fpm from connect to access on the unix_stream_socket /var/lib/mysql/mysql.sock"
Immediately after these updates my customer website started throwing "500" errors
- MariaDB-client 10.11.9-1.el9 from mariadb-main repo (previous version: 10.11.8-1.el9 from mariadb-main repo)
- MariaDB-common 10.11.9-1.el9 from mariadb-main repo (previous version: 10.11.8-1.el9 from mariadb-main repo)
- MariaDB-server 10.11.9-1.el9 from mariadb-main repo (previous version: 10.11.8-1.el9 from mariadb-main repo)
- MariaDB-shared 10.11.9-1.el9 from mariadb-main repo (previous version: 10.11.8-1.el9 from mariadb-main repo)
- galera-4 26.4.19-1.el9 from mariadb-main repo (previous version: 26.4.18-1.el9 from mariadb-main repo)
Database connection is using 'localhost'.
AlmaLinux 9.2
Plesk Obsidian Version 18.0.62 Update #2
I applied @dash 's workaround and website is back to normal and no more setroubleshoot errors in System Log Browser.
Ditto @danami 's query about a fix.
@pleskuser67553 If I remember correctly I don't think that chcon changes will persist if the mariadb packages get updated again. You might want to use semanage and restorecon to apply the mysqld_exec_t label. This should keep it fixed even if mariadb gets updated.
Code:
semanage fcontext -a -t mysqld_exec_t -s system_u "/usr/sbin/mariadbd"
restorecon -v /usr/sbin/mariadbd
I feel this should be flagged for checking during install as when I was setting up a new server with a fresh Almalinux 9.4: if you install MariaDB 10.11 and then install Plesk w/ SELinux checked none of the Wordpress sites can connect. I was at a complete loss for a bit until I turned on DEBUG on WP and with the error landed on this thread.
I used the commands above to get things working.
lol - Google brought me back here again.
  1. New installation of AlmaLinux 9.5
  2. New installation of Plesk Obsidian 18.0.67 Update #2
  3. MariaDB updated to 10.11 using the UI updater.
  4. Subscription migrated using Plesk Migrator extension.
  5. SELinux blocks MySQL socket connection with PHP-FPM 8.4.
  6. Above workarounds resolve.
Please can this get raised as a dev ticket? @Sebahat.hadzhi
And again @Sebahat.hadzhi after auto-update overnight :( This is embarrassing and no longer funny.
CPU: AMD EPYC-Milan Processor (4 core(s))
Version: Plesk Obsidian v18.0.73_build1800251009.17 os_RedHat el9
Operating System: AlmaLinux 9.6 (Sage Margay)
Database: MariaDB 10.11.15
PHP 8.3.27 and 8.4.14
I hit the same issue after upgrading MariaDB via Plesk on AlmaLinux 9:
Plesk was OK, but all PHP sites (WP/Joomla/Roundcube) failed to connect to DB with “Permission denied”.
Root cause was SELinux: MariaDB was running under unconfined_service_t, so httpd_t (php-fpm) was denied connecting to /var/lib/mysql/mysql.sock.
This fixed it permanently for me (no server reboot required):
  1. Temporarily set permissive to keep sites up while troubleshooting:
setenforce 0
  1. Confirm AVC denials and socket path:
ausearch -m avc -ts recent | tail -n 50
mysql -u root -e "SHOW VARIABLES LIKE 'socket';"
ps -eZ | egrep 'mysqld|mariadbd'
In my case: socket was /var/lib/mysql/mysql.sock and mariadbd was unconfined_service_t.
  1. Fix SELinux label on the MariaDB binary:
dnf -y install policycoreutils-python-utils
semanage fcontext -a -t mysqld_exec_t "/usr/sbin/mariadbd"
  1. Critical step: re-exec systemd, then restart MariaDB (this is what moved it from unconfined_service_t to mysqld_t):
systemctl daemon-reexec
  1. Verify MariaDB is now running as mysqld_t:
ps -eZ | grep mariadbd
Expected:
system_u:system_r:mysqld_t:s0 ... mariadbd
  1. Re-enable enforcing and confirm sites work:
setenforce 1
getenforce
Optional: make enforcing persistent:
  • Ensure /etc/selinux/config has SELINUX=enforcing (no reboot needed immediately; it applies on next reboot).
After step 4, all DB connections worked again with SELinux enforcing.
