plesk panel ISO files problem help
mehmett
Here the ISO files, does not work. (Centos or ubuntu)
http://www.parallels.com/download/plesk/images/
Logs
[root]# tail -f /home/plesk/autoinstaller3.log
Getting new version of Parallels Installer...
SourceUrl: original source url is https://autoinstall.plesk.com/Parallels_Installer
SourceUrl: fixed url is https://autoinstall.plesk.com/Parallels_Installer/
FileFetcher new object: target_dir=/var/cache/parallels_installer/, main_source_url=https://autoinstall.plesk.com/Parallels_Installer/
FileFetcher: get file (~empty)/parallels_installer_CentOS_6_x86_64.md5sum
File downloading parallels_installer_CentOS_6_x86_64.md5sum: 100% was finished.
File downloading parallels_installer_CentOS_6_x86_64: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
Getting done, Parallels Installer is ready to restart.
Doing restart of Parallels Installer...
How can I solve this problem? Plesk why this team does not control. It was running before. Plesk 11.5 version does not work?
Thank you.
What exactly does not work here? Could you please explain with more details?
ISO files will not work. Hang. It was running before. Does not return a result. There are no results succeed or fail. Installation does not complete. You can try it yourself.
Hang
wait wait wait. No result !
Thank you for information. We have reproduced this issue and submitted corresponding request to developers (RT #1825003 for your reference)
Developers are working on it.
ISO files will be fixed soon. At the moment you can use following workaround:
1. If autoinstaller is still running (immediately after OS installation) do:
# cp /home/plesk/autoinstaller3.log /home/plesk/autoinstaller3.log.orig; unlink /home/plesk/autoinstaller3.log ; ln -s /var/log/plesk-install/autoinstaller3.log /home/plesk/autoinstaller3.log
2. If autoinstaller has finished its work ( following command show empty string # ps afxww | grep parallels_installer | grep -v grep )
# cp /home/plesk/functions.in /home/plesk/functions.in.orig
# vi /home/plesk/functions.in
[root@localhost plesk]# diff -u /home/plesk/functions.in.orig /home/plesk/functions.in
--- /home/plesk/functions.in.orig 2014-01-15 21:02:20.369055814 -0500
+++ /home/plesk/functions.in 2014-01-15 21:03:35.870108758 -0500
@@ -129,10 +129,10 @@
is_ok()
[ -f "/home/plesk/ok.flag" ] && return 0
- grep -rn 'Exit with success' $ai_log && return 0
- grep 'packages were installed successfully' $ai_log && return 0
- grep 'The installation was finished successfully' $ai_log && return 0
- grep 'The changes were applied successfully' $ai_log && return 0
+ grep -rn 'Exit with success' $ai_log && do_install_complete && return 0
+ grep 'packages were installed successfully' $ai_log && do_install_complete && return 0
+ grep 'The installation was finished successfully' $ai_log && do_install_complete && return 0
+ grep 'The changes were applied successfully' $ai_log && do_install_complete && return 0
return 1
Again same problem. ISO files not working. Error message ;
Parallels Plesk Panel installation has been interrupted.
After the server reboot, the installation will be started again.
See: /var/log/plesk-install/autoinstaller3.log
to get more information.
OS centos 64bit. Please help !
What happened after reboot? Any error messages from logs?
