Plesk Panel Keep On Asking for Login Info
Status
Not open for further replies.
skywalllker
Dear all,
I'm having a weird problem here. I can login to my Plesk panel without any issue but the problem is, when I already logged in and when I click on any link within the interface, Plesk will ask me to re login again. It will appear at random but its kind of annoying. For example, after I set up a new service plan and hitting save button, it will redirect me to login page again, so all my previous settings are gone.
My Plesk version is 11.0.9 running on CentOS 6
Anyone knows what went wrong here?
Thanks in advance!
Yes, I'm accessing my server at SoftLayer from home. My home Internet connection is on dynamic IP but its not constantly changed its IP unless if I reboot the router. Is this the root of the problem?
Yes, that problem you are facing is very common with Dynamic IP networks! If you are sure it's not the IP change, then you can try by deleting ALL cookies and session off your browser ..
Secondly, if accessing your server you are using a domain name who's you are also accessing with your other 'system' if both are on the same browser (and your other system uses sessions / cookies) then that causes conflict of domain sessions ...
Use different browsers for both Plesk and your system (or use server IP to access Plesk)
Status
