Issue [PPP-26546] Error setting FTP storage settings
Flavio
When I try to set FTP storage setting for the backup I receive this error: Transport error: unable to list directory: Curl error: Timeout was reached
I have the same situation on server Centos 6.8 and Windows 2008 R2, both with this error after plesk onyx upgrade.
This option work fine last week, before I upgrate plesk from 12 to onyx.
The access to the FTP server work fine if I use filezilla or windows ftp command
Are you able to telnet your remote ftp server port 21 from your server? just to make sure that it's able to communicate.
Thank you.
have you read the answers :
https://talk.plesk.com/threads/ppp-26478-after-update-to-onyx-backup-does-not-work.339594/
there seems to be a bug with the ftp timeout, i think in the next update it will get fixed. you can try what Sergey Prohorov said
Could you try to add following section at end of panel.ini (/usr/local/psa/admin/conf/panel.ini on Unix or "%plesk_dir%\admin\conf\panel.ini" on Windows) and restart backup.
Code:
[pmm]
ftpFileTransferTimeout = 36000
If you already has 'pmm' section in this file - just add 'ftpFileTransferTimeout' to the section.
This workaround increases file transfer timeout to 10 hours.
Hello, Flavio. Could you send me PM with output of following command:
Code:
DUMP_STORAGE_PASSWD=<FTP password> /usr/local/psa/admin/bin/pmm-ras --check-repository --dump-storage=ftp://<FTP login>@<FTP host>/<FTP directory> --use-ftp-passive-mode --debug --verbose --session-path=/var/log/plesk/PMM
It contains CURL debug output from checks we do before save FTP storage configuration.
Hello Sergey,
here the output log created by your command:
[2016-10-19 09:56:30.320|12984] INFO: pmm-ras started : /usr/local/psa/admin/bin/pmm-ras --check-repository --dump-storage=ftp://[email protected]/backupserver/cloudlinux --use-ftp-passive-mode --debug --verbose --session-path=/var/log/plesk/PMM
[2016-10-19 09:56:30.320|12984] INFO: Repository 'ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux': Initializing...
[2016-10-19 09:56:30.320|12984] INFO: Transport: Get repository transport ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux
[2016-10-19 09:56:30.320|12984] INFO: Transport: Init credentials for user 'ftpbackupsrv'
[2016-10-19 09:56:30.320|12984] INFO: Curl version: 0x72300
[2016-10-19 09:56:30.322|12984] INFO: Repository 'ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux': Initialized
[2016-10-19 09:56:30.322|12984] INFO: Test stage: Check directory access
[2016-10-19 09:56:30.322|12984] INFO: Transport: List dir /
[2016-10-19 09:56:30.322|12984] INFO: Ftp init url ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux/
[2016-10-19 09:56:30.323|12984] INFO: Created temp file: /usr/local/psa/PMM/tmp/repo_transport_tmp_PQe8zo
[2016-10-19 09:56:30.323|12984] INFO: Ftp extended list dir
[2016-10-19 09:56:40.325|12984] INFO: Curl output :
[2016-10-19 09:56:40.325|12984] INFO: * Hostname was NOT found in DNS cache
[2016-10-19 09:56:40.325|12984] INFO: * Trying 151.66.143.22...
[2016-10-19 09:56:40.325|12984] INFO: * Connected to qnapafdox.dyndns-office.com (151.66.143.22) port 21 (#0)
[2016-10-19 09:56:40.325|12984] INFO: < 220 NASFTPD Turbo station 1.3.5a Server (ProFTPD) [192.170.1.50]
[2016-10-19 09:56:40.325|12984] INFO: > USER ftpbackupsrv
[2016-10-19 09:56:40.325|12984] INFO: < 331 Password required for ftpbackupsrv
[2016-10-19 09:56:40.325|12984] INFO: < 230 User ftpbackupsrv logged in
[2016-10-19 09:56:40.325|12984] INFO: > PWD
[2016-10-19 09:56:40.326|12984] INFO: < 257 "/" is the current directory
[2016-10-19 09:56:40.326|12984] INFO: * Entry path is '/'
[2016-10-19 09:56:40.326|12984] INFO: > CWD backupserver
[2016-10-19 09:56:40.326|12984] INFO: * ftp_perform ends with SECONDARY: 0
[2016-10-19 09:56:40.326|12984] INFO: < 250 CWD command successful
[2016-10-19 09:56:40.326|12984] INFO: > CWD cloudlinux
[2016-10-19 09:56:40.326|12984] INFO: > EPSV
[2016-10-19 09:56:40.326|12984] INFO: * Connect data stream passively
[2016-10-19 09:56:40.326|12984] INFO: < 229 Entering Extended Passive Mode (|||56408|)
[2016-10-19 09:56:40.326|12984] INFO: * Hostname was NOT found in DNS cache
[2016-10-19 09:56:40.326|12984] INFO: * Trying 151.66.143.22...
[2016-10-19 09:56:40.326|12984] INFO: * Connecting to 151.66.143.22 (151.66.143.22) port 56408
[2016-10-19 09:56:40.326|12984] INFO: * Operation timed out after 10001 milliseconds with 0 bytes received
[2016-10-19 09:56:40.326|12984] INFO: * Closing connection 0
[2016-10-19 09:56:40.326|12984] INFO: Curl error (28): Timeout was reached
[2016-10-19 09:56:40.326|12984] INFO: CurlError[76931fac-9dab-42b3-86c2-48b87d6ae33f]: Curl error: Timeout was reached [./ftp.cpp:484]
void plesk::tFtpConnection::ListEx(std::vector<plesk::FtpFileInfo, std::allocator<plesk::FtpFileInfo> >&)
[2016-10-19 09:56:40.327|12984] INFO: pmm-ras finished. Exit code: 126
thanks.
It looks like another issue with too small timeout. Could you run following curl command
Code:
time curl --verbose --ftp-pasv --netrc-file ~/my-password-file ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux
~/my-password-file should contain following data:
Code:
machine qnapafdox.dyndns-office.com login ftpbackupsrv password <PASSWORD>
Have you tried to do not use passive mode?
in which folder I must create the file my-password-file ?
and Yes, I've try to don't set passive mode but the result is the same.
You could create it any secure place - just specify a full path to this file in '--netrc-file' option of curl command.
If you have older curl version (which you do), you may just create the file with the suggested content with the ~/.netrc path (i.e. create .netrc file in your home directory). Then call curl with --netrc command option instead of --netrc-file /opt/my-password-file option.
Here the result of the command:
[root@cloudlnx ~]# time curl --verbose --ftp-pasv --netrc ftp://qnapafdox.dyndns-office.com/backupserver/cloudlinux
* About to connect() to qnapafdox.dyndns-office.com port 21 (#0)
* Trying 151.66.143.22... connected
> USER ftpbackupsrv
> PASS mypassword
> PWD
* Entry path is '/'
> CWD backupserver
> EPSV
< 229 Entering Extended Passive Mode (|||55991|)
* Trying 151.66.143.22... Connection timed out
* couldn't connect to host
* got positive EPSV response, but can't connect. Disabling EPSV
> PASV
< 227 Entering Passive Mode (151,66,143,22,195,82)
* Connecting to 151.66.143.22 (151.66.143.22) port 50002
> TYPE I
< 200 Type set to I
> SIZE cloudlinux
< 550 cloudlinux: not a regular file
> RETR cloudlinux
< 550 cloudlinux: Not a regular file
* RETR response: 550
* Remembering we are in dir "backupserver/"
* Connection #0 to host qnapafdox.dyndns-office.com left intact
curl: (78) RETR response: 550
> QUIT
< 221 Goodbye.
* Closing connection #0
real 1m3.612s
user 0m0.001s
sys 0m0.011s
