Resolved Migration connection issue
ashley
Basic Pleskian
Almalinux 10 target. Centos 7 source
18.0.74 Target 18.0.57 source
I am trying to start a migration but it fails at connection. Obsidian to Obsidian migration.
Error message is "Failed to check SSH connection to the source server 'source' (IP ADDR):"
SSH keys generated on target and pub key copied to source authorized_keys file.
I can ssh from target to source fine. So firewall fine. I can also use the SSH terminal within plesk and that connects fine.
When i use migration tool i receive the error message.
On source i see the following error in /var/log/secure
sshd[7316]: dispatch_protocol_error: type 90 seq 3 [preauth]
I just migrated an identical (probably!) server to the problem one without issue.
Web trawling isn't helping figure this out. Maybe someone has an idea!?
Hello, @ashley . Is root login permitted on the servers? Please try executing the following command on the source and destination servers:
Code:
grep -i permitrootlogin /etc/ssh/sshd_config
Yes, as mentioned i can run ssh at command prompt and in Plesk SSH terminal using just
#ssh [IP ADDR}
Can you check the info.log and debug.log for errors in /usr/local/psa/var/modules/panel-migrator/sessions/<date>/*
info.log is claiming no connection
[ERROR] Unable to connect to 'IP ADDR' by SSH: not a valid OPENSSH private key file. Retrying in 10 seconds
debug.log saying the same
core.utils.ssh_utils|||Unable to connect to 'IP ADDR' by SSH: not a valid OPENSSH private key file. Will exclude old keys hashing algorithms and try again.
core.utils.ssh_utils|||Exception:
So migrator doesnt like the private key file whereas standard connection works?
Could be different things.
- How did you create the ssh-key? With the same type as the other servers?
- Did you check the file- and directory permissions of the .ssh directory and the files inside .ssh/*? Those are very strict.
Thanks for your help. I clearly did something wrong and because ssh worked at command line i got blind to the basics, Started at the beginning again and now working.
