Power Toys 3.1
Status
Not open for further replies.
is already there, just I need to get some time to package the software :))
dooooh this time, someone can make me a program (can be in any language) which will extend my day to 48 hours? :))
Good news lvalics!!! i really like the option to send a welcome mail with username and password too @ my Clients with Power Toys in a simple text mail .. well done! :D
OK, done.
Please on upgrade save your EMAIL TEMPLATE.
WHAT IS NEW IN:
+ new features
! bug fixing or improvements
- removed from software
3.5
+ VHOST Writer - now you can have access to VHOST.CONF
Please be sure that you knwo what you are doing, is really a power toy, but can blow up if you play nasty with it.
We have some predefined templates and we are open to any ideeas, if you have some.
+ Domain alias - This toys will allow you to add a domain alias, with DNS settings as well.
+ Uninstaller - will uninstall Power Toys.
! Password Revealer - now if you send to client, you can send as well the client details (login, password)
Also you can choose to send HTML or TEXT mail.
TO DO:
! Debian detection in installer and do bind:bind rights on named
! To not owerwrite mail template files on upgrade
Hi, first of all thanx for your work, i already installes 3.5 and i have problem with new option on Password revealer:
when i choose text i have a blank page and no mail sent
when i choose html i have a page with "mail sent" but no mail sent
Please help me for this long waiting option :)
thanx in advance
[root@www.garmtech.lv root]# ./installer.sh
Installing:
Creating /usr/local/psa/admin/htdocs/psapt3.
Extracting data.
x - creating lock directory
x - extracting data.tgz (binary)
Extracting archive to /usr/local/psa/admin/htdocs/psapt3.
Setting file permissions.
Setting wrapper.
./installer.sh: line 86: dos2unix: command not found
after install: PLESK 7.5.x (version 3.4). Does it really 3.4 or 3.5? installer.sh is # Power Toys 3.5 Install Script.
We will see how can we skip if dos2unix not exist.
It is necesserry if we leave ^M lines in shell files or in wrapper and then errors can be popup later.
... any solution for mail problem with password revealer? i love this option :)
I tried the domain alias solution, but I have a doubt.
Plesk stores domain mail configuration in mysql psa database, when it checks de config and rewrites config files (rcpthosts, virtualdomains) it not include the alias domain.
I tried manually with mchk and the alias was eliminated by it.
It involves that the domian alias solution is not "stable"
We tried to focus on domain alias, not on mail alias. I think is important to alias domains in this phase.
Anyway 4PSA have a more advanced module for this.
We do not have time to study that part, sorry, maybe in a future version. Source is open, so you can add if you like anything in source and send to us the modifications.
Originally posted by lvalics
OK, done.
WHAT IS NEW IN:
+ new features
3.5
TO DO:
Were is the 3.5 version for download?
upgrade failed!!
----<START QUOTE>----
modulemng failed: /tmp/phpL234v9: not an rpm package (or package manifest):
Installing:
Extracting data.
x - crating lock directory
Extrating archive to /usr/local/psa/admin/htdocs/psapt3.
Setting wrapper.
modulemng: error: Installing failed
----<END QUOTE>----
Can you, please help me?
I'm running PLESK 7.5.3 on FC2
sorry to say, but this doesnt work.
It doesnt alias at all on my box.
Red Hat Enterprise Linux ES release 3 (Taroon Update 5)
Plesk 7.5.3 Reloaded for linux RPM install
Until I release new fix, edit password_remainder.php and on line 537 $fte->define(array("main"=>"send_password_text.html")); change to $fte->define(array("main"=>"send_password_txt.html"));
We misstyped text = txt.
After trying to install it over the command line, i get this error:
Installing:
Extracting data.
Setting wrapper.
dos2unix: converting file /usr/local/psa/admin/htdocs/psapt3/wrapper.c to UNIX format ...
./installer.sh: line 87: gcc: command not found
Any ideias how to solve this?
I have PLESK 7.5.3 on FC2
Thank you so much Ivalics ... with your work you gave me more time to go to fishing .. :)
In config.inc.php define("LANG_VERSION", "3.4"); should be define("LANG_VERSION", "3.5");
Status
